Author Topic: KATO SHELL Loose  (Read 1357 times)
  • Respect: +4178
KATO SHELL Loose
« on: May 28, 2017, 07:19:00 AM »
I've got an AC4400 shell that no longer snaps tightly into the little knob on the frame and rides up a little .. this makes the coupler ride high .. any thoughts on how to rig this up?
Th
nscaler711
  • Respect: +271
Re: KATO SHELL Loose
« Reply #1 on: May 28, 2017, 07:23:19 AM »
I have used a little bit of tape on the nubs on a couple frames and that seems to snug them up a little bit...
But it may or may not work for you...
migalyto
  • Respect: +7
« Reply #2 on: May 28, 2017, 07:30:36 AM »
How about a couple small dabs of silicon applied with a toothpick? It would hold decent and take some vibration. Plus you can still get the shell of at a later time if need be.
ns737
  • Respect: +38
« Reply #3 on: May 28, 2017, 10:11:51 AM »
HI is the frame to tight?
  • Respect: +4178
« Reply #4 on: May 28, 2017, 12:15:43 PM »
No .. what happens is that there are little dimples on the frame, and they fit into small depressions molded into the side of the shell .. after a while this depression in the shell wears some, and it no longer tightly holds the shell down ..
I put some plastic tape into the shell, and it seems to work
  • Respect: +2883
« Reply #5 on: May 28, 2017, 12:21:44 PM »
... I put some plastic tape into the shell, and it seems to work
That's what I've done. I first tried regular electrical tape; it was too thick and caused the shell to bulge. The 3M plastic tape for repairs or whatever is thinner and seems to do the job.
Big Train
  • Respect: +11
« Reply #6 on: May 28, 2017, 01:49:37 PM »
Can you loosen the screws and nut assembly that holds the frame together just a quarter turn?. It's possible these may have been adjusted too tight after re-assembly.
Hope this helps....
  • Respect: +4178
« Reply #7 on: May 28, 2017, 05:45:54 PM »
Hope this helps....
Never thought of that :)
